lowering a renault 9 ?
Post hier al je vragen over de Renault 9 en 11
Postby schakal » Sun 15 Apr 2007 8:18
i have just finished my r9 16v converison
and want to lower it on some uprated shocks and
springs as well as the rear end .
i would appreciate any input on what sort of lowering kit
to buy and how low i can go at the rear without messing the
handling and the drive comfort as this car is gonna be
a daily driver for me
thanks in advance (Y)
schakal
Postby MartijnG » Sun 15 Apr 2007 8:39
You can try Renault 5 GT Turbo shocks (with lowering springs) but you have to modify the upper mounting because the bolt holes on the shock and on the car are not the same.
I was going to try it on my Renault 9 once, but before I could fit them I sold my car :wink:
I even think that there are lowering springs for a Renault 9? That will be a -35mm lowering if i'm correct.
The rear axle can be lowered by adjusting the torsion bars. I guess that is going to be a hell of a job. It probably will be full of rust (N)
Good luck (Y) :)
'85 GT Turbo & '85 5TL & '90 5TR-T "Rusty" & '79 Estafette Campert & '86 GT Turbo & '89 5GTX & '02 Clio II 1.5 dCi & '05 Megane 1.9 dCi (Daily) & '91 Clio 16v & '03 Clio II 1.6 16v Initiale LPG (Daily) & '06 Megane II Grand Tour 1.6 16v LPG (Daily)
User avatar
Donateur
Postby schakal » Sun 15 Apr 2007 8:45
MartijnG wrote:You can try Renault 5 GT Turbo shocks (with lowering springs) but you have to modify the upper mounting because the bolt holes on the shock and on the car are not the same.
Good luck (Y) :)
thanks mate ,
i always thought the renault 5 turbo front shocks
were much different than the r9/11 ones ??
are you sure these fit fine ??
i bought a set of 35 mm lowering springs for my renault 9
off ebay ,they dont lower the car at all :(
yeah my torsion bars are seized as well but i will
sort that problem pretty soon with some :mg:
schakal
Postby MartijnG » Sun 15 Apr 2007 9:23
The two bolt holes on the top of the GT Turbo shocks don't align with the bolt holes on the Renault 9. So you have to drill a extra hole in your car. It sounds very crappy, but there are some guys on this forum who did it as well...so probably that's the only solution :)
User avatar
Donateur
Return to Renault 9 en 11
